Layer is not shown in the TOC after load shapefile
5114
21
12-13-2012 09:44 AM
LeonardoAraújo
Hi all,
I'm trying to use the Load Shapefile widget (http://www.arcgis.com/home/item.html?id=bc6a88cf51364d9ea767347954363d7d) and am having a problem after loading a file. The features are loaded successfully but the TOC does not display the new layer. Could anyone help me on this?
RobertScheitlin__GISP
Leonardo,
  The featureCollection needs a LayerDetails
var layerDetails:LayerDetails = new LayerDetails(); featureLayer.featureCollection = new FeatureCollection(featureSet, layerDetails);
I will be coming out with an enhanced Shapefile widget very soon that handles re-projecting the shapefile and adding each shapefile and labels as different layers in the TOC, as well as other features.
Leonardo,
  That is because the ShapeFile widget adds the shapefiles to a graphics layer and not a normal type that would show in the TOC.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
LeonardoAraújo
Leonardo,
Dear Robert,
I've tried changing the GraphicsLayer to FeatureLayer according to the code below but had no success. The layer is displayed in the table but the features were not shown on the map. Am I doing something wrong?
while (shpReader.hasMore()) {
   array.push(new Graphic(...
var features:Array = [];
for each (var geometry:Geometry in GraphicUtil.getGeometries(array))
features.push({ geometry:geometry });
featureSet.spatialReference = map.spatialReference;
featureSet.features = features;
featureLayer.featureCollection = new FeatureCollection(featureSet);
featureLayer.id = layerName;
featureLayer.name = layerName;
map.addLayer(featureLayer, 1000);
Leonardo,
LeonardoAraújo
Leonardo,
Thank you very much Robert! It worked perfectly. I'll be waiting for your new widget and certainly will use it in my application.
LeonardoAraújo
Leonardo,
   Here is the link
http://www.arcgis.com/home/item.html?id=2e9096c5d5044d39a264df759611686f
Thank you Robert, I am trying to use your new widget but there must be some problem with my geoprocessing service. The reprojection task never ends and a empty alert window is shown. You could tell what can be?
Leonardo,
   Did you read the readme.txt where it said you need to use an ArcGIS Server 10 Geometry Service.
LeonardoAraújo
Leonardo,
Yes, I am using ArcGIS Server 10 SP4 geoprocessing service.
Leonardo,
   You are meaning to say Geometry Service right?... And you have you Flex Viewers main config.xml point to your Geometry Service?
