labels with backgrounds
1571
04-16-2013 02:55 AM
MikeSmith7
I have been trying to publish my layer and keep getting "Layer is using unsupported setting (KML)".  Is there a way in the flex viewer to change the label background.  I simply want a label that has a solid background so that it stands out.  Does anyone have a way to either publish the service with the label style I want or change it in flex?
As well, is there a code I can put in the text to add a carriage return, that is a bonus.
Mike
MattPohl
Hi Mike,
I don't use KML in any of my services, but it looks like you are running into the issue described here: http://resources.arcgis.com/en/help/main/10.1/index.html#//00sq000000r9000000
It appears that ArcGIS doesn't support halos (backgrounds) for KML layers. Unless someone has found a workaround you might be stuck using a standard label with the KML. You could always convert the KML to a feature class before publishing and your labels will come through just fine.
Matt
MikeSmith7
Hi Mike,
Matt
Unfortunately my labels are dynamic and generated by our vehicle tracking data.  We change label and add a time stamp if a vehicle has not reported in for a particular duration or if other events occur.
RhettZufelt
MVP Notable Contributor
So, do you not have AcrGIS Server or something?
Otherwise, is there a particular reason that you are loading it as KML in the first place and not just publishing as a "normal" service so the labels work as "expected"?
by "normal" I mean from a feature class or event theme.
R_
