Jumping into widget-olgy
1849
01-27-2012 05:36 AM
by Anonymous User
Not applicable
Original User: Richmondgis
Ok,  I have a test flex site up and running using the application builder.  All seems good there.....Now I would like to add some simple functionality and my first several attempts have failed (imagine that!).
My goal:
  • To have a flex site that shows my County's parcels and streets overlaid on a basemap.  Done!
  • To add another layer of pre-identified parcels based on attribute criteria.  Done ( I am joining a copy of the orginal parcel layer (which is an SDE view) to an excel table.  This table will be populated with parcel infomation as parcel are included in the selection)  I did get this to work, but not sure if using a join in this instance would be the best idea moving forward.  I might retreat into using a complete separate layer in this instance (shapefile).
  • the end user of this flex site would need to be able to search for a property (pin, owner, and/or address) and auto zoom to property - then click a button (widget?) to buffer the pre-identified properties (as provided in the other layer) and determine if the property found from the search falls within a 1 mile buffer of those pre identified  properties.
The purpose of this site is to help folks determine if thier property falls wthin a Voluntary Agricultural District (VAD).
I have tried creating a buffer tool using model builder in ArcMap, and published the tool to the ArcServer. I am not sure I am loading it correctly into the flex application as it does not work.  I have reveiwed several posts on this and related subjects, and seem to think I am missing a critical part of this development process.  Can a published tool be directley used in the flexviewer?  Is there a step or two I am not seeing?
Any pointers, suggestions, advice would be most helpful.  I have used a published tool before in manager, but it has been a while.  I really would like to get more knowledgeable in the flex environment.  Thanks in advance for reading and hopefully repsonding to this thread.
James Armstrong
by Anonymous User
Not applicable
Original User: GISProgrammer9
Robert's widget will do what you need:
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
by Anonymous User
Not applicable
JamesArmstrong
Thanks,  I have seen this widget and thought it would work for the search.  My real issue was the buffering tool, but now I am think that I can create this buffer layer myself and serve it out as a static.  I guess I was more intereted in figure out how to do it, than I was in getting the information out.
I will post back to this thread when I get close to finishing.
thanks again
JEA
by Anonymous User
Not applicable
thanks again
JEA
If I understood your workflow correctly, Robert's e-search will do the buffering you need. No need to go the geoprocessing part, and yes it it not very intuitive as you have found out the hard way.
