Issues with Weather Underground Widget 2.1
1493
10-06-2010 05:00 AM
by Anonymous User
Not applicable
Original User: xander
I have tried both the compiled and uncompiled versions with the same results. I do not receive any compile errors and the widget appears to load just fine.
1) The search stutters, but will eventually work after a few tries.
2)  I do not see any radar results
3)  I only see a partial 6-day forecast
I have attached a couple of screen shots.
RobertScheitlin__GISP
xander,
    The issue you are having has to due with Adobe tightening their security standards in flash player 10. You are attempting to run the widget from your local drive instead of setting your flexviewer project to run through a web server and therefore are hitting several security sandbox errors. You can make these all go away if you setup a virtual directory (is using IIS) and setting the output folder url of your flexviewer project as recommended by esri here. http://help.arcgis.com/en/webapps/flexviewer/help/developers/gettingstarted_dev.htm
