Is there a widget with Profile Graph Tool?
3906
8
07-22-2013 05:14 AM
RokCiglic
Hi!
I am looking for a widget that would give an option of making a profile graph. Is there any available. I have a application with different raster layers and I would like that users draw a line and get a profile graph.
Thank you for any advice!
Rok
AnthonyGiles
Honored Contributor
Rok,
I have only used the .net SOE so cannot comment of the java.
Your URL in the widget does not look correct as it should end in getelevations, try:
http://gismo.zrc-sazu.si:6080/arcgis/rest/services/test/test_tem/MapServer/exts/ElevationsSOE_JAVA/E...
Regards
Anthony
P.S. I tried a test against your service through the REST endpoint at it is returning a temperature value, see:
GISDev1
Hi!
Rok
Elevation profile widget
http://www.arcgis.com/home/item.html?id=b9d247c297f144459854751740f59f68
RokCiglic
Thanks, but can I use other data indstead of elevation. I have air temperature data (raster) and I want to make profile with this data.
GISDev1
Yes, of course you can.
RokCiglic
I saw widget's xml file and noticed that file for which profile is built is:
<elevationSOEURL>http://sampleserver6.arcgisonline.com/arcgis/rest/services/Elevation/WorldElevations/MapServer/exts/...</elevationSOEURL>
Does SOEURL mean that you have to use server object extension ( http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#/What_is_a_server_objec... )
I'm not familiar with SOE and don't have software. Is there any easier way?
AnthonyGiles
Honored Contributor
Rok,
The SOE can be downloaded here, it has instructions for deploying which is vey simple:
http://www.arcgis.com/home/item.html?id=60bf17f2d59441839135adc25654a7d9
Regards
Anthony
RokCiglic
Thanks for the advice!
I intalled ElevationsSOE (I installed SOE for JAVA, should I installed also SOE for NET??) and I can see it and can check it in my Services --> Capabilites menu.
I also import Elevation Profile widget into AppBuilder. I made this settings (see below) in Elevation profile widget, but when I try my application it says:
"A problem occured while parsing and charting the returned elevation data Error #1010"
I use map temperatures instead of elevation, but this shouldn't be a problem (values are between 12 and 26!).
Is it something wrong with this SOEURL or widget code?
<configuration>
    <elevationSOEURL>http://gismo.zrc-sazu.si:6080/ArcGIS/rest/services/test/test_tem/MapServer/exts/ElevationsSOE_JAVA</elevationSOEURL>
    <profileLineWidth>2</profileLineWidth>
    <profileLineColor>0x000099</profileLineColor>
    <description>Draw a line with the tools below; ArcGIS will create an temperature profile chart for it.</description>
    <chartTitle>Temperature Profile</chartTitle>
    <baseChartAtZero>true</baseChartAtZero>
    <unitsAndLabeling>
        <elevation>
            <label>
                <chart>degrees</chart>
                <dataTip>C</dataTip>
            </label>
            <multiplyByToConvertFromMeters>1</multiplyByToConvertFromMeters>
        </elevation>
        <distanceAlongPath>
            <label>
                <chart>kilometers</chart>
                <dataTip>km</dataTip>
            </label>
            <multiplyByToConvertFromMeters>0.001</multiplyByToConvertFromMeters>
        </distanceAlongPath>
    </unitsAndLabeling>
    <template-ignoredByCode>
        <unitsAndLabeling>
            <elevation>
                <label>
                    <chart/>
                    <dataTip/>
                </label>
                <multiplyByToConvertFromMeters/>
            </elevation>
            <distanceAlongPath>
                <label>
                    <chart/>
                    <dataTip/>
                </label>
        </unitsAndLabeling>
    </template-ignoredByCode>
</configuration>
AnthonyGiles
Honored Contributor
Rok,
Regards
Anthony
RokCiglic
Thank you! It works now!
Rok
