Is Map Legend Widget using Rest Legend going to work with AGS 10.1?
2003
8
01-29-2013 10:12 AM
KevinKimm
Hi, I am currently using the Map Legend Widget using Rest Legend with ArcGIS Server 10 and Flex API 2.4.
Before upgrading to ArcGIS Server 10.1 and Flex API 3.1, I want to know if the Map Legend Widget I am using now is still going to work with AGS 10.1 and Flex API 3.1
Does anyone know about this?
GISDev1
Please clarify what you are referring to as the "Map Legend Widget".
AnthonyGiles
Honored Contributor
Ben,
Are you using the out of the box legend or is it one that you have modified yourself? There is a legend in 3.1 that should work ok:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Legend_widget/01m30000003400000...
Regards
Anthony
KevinKimm
I think this Widget was called as "Live Maps Widget" in the past. It gets map Legend images from web services which uses ArcGIS Server .NET ADF library.
AnthonyGiles
Honored Contributor
Ben,
I think the live maps widget is one of Roberts it's now called the table of contents/legend widget is has been updated to 3.1:
http://www.arcgis.com/home/item.html?id=e2cb71d5c04d40d19e9f945ae0db7ce8
Regards
Anthony
KevinKimm
Ben,
Regards
Anthony
I see. I tested the new legend widget of Roberts, but for some reasons, some legend symbols don't show up right. They looked good in the LiveMapsWidget. If possible, I want to continue to use the LivaMapsWidget on AGS 10.1 and Flex API 3.1. Is it technically possible?
AnthonyGiles
Honored Contributor
Ben,
It depends on if you are using compiled or uncompiled code. If compiled then no you will have to upgrade. If you have the source code then bring it into your application, work through any errors then re-publish it may work
Regards
Anthony
KevinKimm
Ben,
Regards
Anthony
I see. Thanks. I use uncompiled code. So, AGS 10.1 still supports SOAP based .NET ADF web services. Right?
AnthonyGiles
Honored Contributor
As far as I am aware yes, have a look at the deprecation plan:
http://downloads2.esri.com/support/TechArticles/ArcGIS10and101Deprecation_Plan.pdf#page5
Regards
Anthony
