I have a problem that appears sometimes when the application is loaded. You can see on picture 1 than my initial extent is not loaded as it should. In the picture 2 you can see the normal display, I just reload the application...
...if so, read about half way down on the first page of that thread, I had the same issue. Robert Sheitlin updated the code to fix the problem (his updated code is also in the same thread I believe).
