Image and Links in Pop-ups Help
8915
44
05-17-2011 08:49 AM
EmilyLaMunyon
Hello,
I am interested in having an image and/or link appear in my pop-ups in Flexviewer 2.3. I have been successful getting the pop-ups to work, just not with an image or hyperlink. I know I am missing something simple, but does anyone have any insight? Thanks!
PopUp_weeds.xml
?xml version="1.0" ?>
<configuration>
    <title>{name:}</title>
    <fields>
        <field name="Name" alias="Name"
        visible="true"/>
    </fields>
<medias>
  <media  type="image" imagesource="{http://website/flexviewer_weeds/weed_pics/{Name}.jpg}" imagelink="{http://website/flexviewer_weeds/weed_pics/oxeye_daisy.jpg}"/>
</medias>
    <showattachments>true</showattachments>
</configuration>
    Pop-up configuration file for:
    http://www.gis.slco.org/wwwrest/services/public/Weeds/MapServer/31
config.xml<layer label="Weeds" type="dynamic"  visible="true" alpha="1"
                   url="http://www.gis.slco.org/wwwrest/services/public/Weeds/MapServer">
       <sublayer id="31" popupconfig="popups/PopUp_weeds.xml"/>
       </layer>
MehulChoksey
try removing extra curly braces in medias tag:
<medias>
  <media  type="image"  imagesource="http://website/flexviewer_weeds/weed_pics/{Name}.jpg"  imagelink="http://website/flexviewer_weeds/weed_pics/oxeye_daisy.jpg"/>
</medias>
also if you want to display name:<Name> in the title tag then title tag should be:
<title>name:{Name}</title>
EmilyLaMunyon
Thanks for the help, that seemed to do the trick, however, my images are blank using the {Name}.jpg option. This may be obvious, but do the image names need to exactly match those of the REST service name?
Thanks!
MehulChoksey
Basically using field name "Name" in your case in curly braces {Name} ,  substitutes the value of the Name field.
Could you use tool like fiddler/firebug to capture HTTP response and pos it here?
EmilyLaMunyon
Thanks, I finally got it to work! One thing I am noticing is that the image does not fill the entire pop-up. Is there a way to specify the specs of the pop-up?
I appreciate your help!
MehulChoksey
Using just the config wont be enough.You will have to work with source code and modify PopupRenderer skin.
EmilyLaMunyon
Can I achieve this without the use of Flash Builder or do I need it to chnage the skin?
MehulChoksey
You will have to modify the popup renderer skin and compile the source either using Flash Builder or by using Flex SDK 4.X
RyanEckdale-Dudley
Is it possible to create link to a url using a field that has a unique url for each feature without displaying the url?  using Pop-ups
MehulChoksey
Could you explain bit more? may be with example...
