Identify Widget
4655
03-01-2015 11:29 PM
ReginaldoPaderon
I am trying to use Basemaps online from ESRI as my basemaps.  Our data is in projected UNITS ( QND 1995 ) .   Data is fine, seats well with the Imagery or Topographic basemaps.
Before doing this I was using our services as basemaps ( same coordinate system )
However, the Identify Widget stopped working.
I am using Flex App Builder 3.6
Any Ideas.
Thanks.
Tags (1)
RobertScheitlin__GISP
Reginaldo,
   Can you provide your main config.xml file for review?
ReginaldoPaderon
Hi Robert,
Somehow I was able to make it working.  I totally removed our basemaps in QND95 and put ESRIs online basemaps, Identify widget working.
Now map is in geographic coordinates.  The problem now is the Locate Widget.  I would like to use still our projected units ( QND95 ) in the Locate Widget ( XY ) .  There was a GOTO XY widget which lets u define your preferred coordinate system but it stopped updating its widget.
Any suggestions?
Many thanks.
ReginaldoPaderon
Sorry Robert,
I just came across your enhanced Locate Widget.  I think this is what I am looking for.
ESRI should be thankful for all the enhancement you have done for their widgets  🙂
You're a great help
