Identify Widget version 2.5.3 for FlexViewer 2.5
1280
03-20-2012 06:45 AM
KenCarrier
Robert,
Is there a way to keep the popup from this widget visible when transitioning from the widget itself to the popup window?
I noticed once you move out of the widget towards the popup, the popup disappears and it is hard to get it to come up again.
Other than that the widget is performing great, the documentation really is helpful.
The only other thing I noticed is when the widget is preloaded and mappoint is activated by default, the first time a user clicks the identify does not always work as expected.
When I took the preload off in the config.xml and loaded it manually I did not see the same behavior.
RobertScheitlin__GISP
Ken,
   Your request is now part of version 2.5.5.
Ken,
KenCarrier
Ken,
Thanks Robert very much appreciated.
