Identify Widget question
1566
8
09-01-2011 05:38 AM
BarryHill1
When using the IdentifyWidget the result is capturing the raster image (Streetmap, Aerial, Topo). Looking at the IdentityWidget config file I see the "Identifylayeroption" is set to 'visible'. I just want to identify the layers that are coming from my Server map service. I tried setting the parameter to 'top' and 'all' but get the same result. This is my first Flexview project so please excuse my ignorance. Thanks.
RobertScheitlin__GISP
Barry,
  You would need to use the:
<layers onlythese="true">
and then specify all the layers that you want results for.
DavidCaussin
hi Robert,
Just a question over this identify widget.
Is it possible to implement a "gridresult" as in the esearch widget?
Is it a lot of work for you?
Thanks.
David
David,
   I have no plans to do that.
KarenRobine
Funny you just asked that.
David: Will you be adding that?  It gets a little more complicated since we will be dealing with multiple layers and it looks like the Grid for the Enhanced Search only handles one layer.
OranousDanandeh
Hi all,
I was wondering if anyone can help me with the identify Widget. I just downloaded the compiled version of flexviewer 2.4 and downloaded the identify widget as well. I am getting error #2036.
I have not seen any examples on how config.xml is configured.  is there a place to specify the url for the map service that I am missing.  Thanks in advance for your help
Oranous
I have added the following to config.xml
<widgetcontainer layout="float">
<widget label="Identify features" left="410" top="280"
                icon="assets/images/i_about.png"
                config="widgets/IdentifyWidget.xml"
                url="widgets/IdentifyWidget.swf"/>
</widgetcontainer>
and identifyWidget.xml is as follows:
<?xml version="1.0" ?>
<configuration>
<identifylayeroption>visible</identifylayeroption>
<identifytolerance>5</identifytolerance>
<defaultzoomscale>5000</defaultzoomscale>
<keepidentifyactive>true</keepidentifyactive>
         <!-- possible values are extent or polygon or mappoint or polyline or nothing -->
<labels>
  <zoom2message>Click to Zoom to Point</zoom2message>
  <identifylabel>Identify</identifylabel>
  <resultslabel>Results</resultslabel>
  <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel>
  <pointlabel>Identify by Point</pointlabel>
  <linelabel>Identify by Polyline</linelabel>
  <rectlabel>Identify by Rectangle</rectlabel>
  <polylabel>Identify by Polygon</polylabel>
  <clearlabel>Clear</clearlabel>
  <loadinglabel>Loading...</loadinglabel>
</labels>
<useproxy>
  <proxylayer>
   <!--name>Imagery</name-->
  </proxylayer>
</useproxy>
<layers onlythese="false">
  <layer>
   <name>Water Mains</name>
   <fields>MATERIAL,DIAMETER</fields>
   <linkfield></linkfield>
   <linkprefix></linkprefix>
   <linksuffix></linksuffix>
   <iconfield></iconfield>
   <iconprefix></iconprefix>
   <iconsuffix></iconsuffix>
   <zoomscale>15000</zoomscale>
   <forcescale>true</forcescale>
  </layer>
</layers>
<symbols>
     <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid">
      <outline color="0x448ccb" alpha="0.8" width="2"/>
     </simplefillsymbol>
     <simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0">
      <outline style="solid" color="0xffffff" alpha="0.8" width="1"/>
     </simplemarkersymbol>
     <picturemarkersymbol url="assets/images/i_about.png" height="30" width="30" xoffset="0" yoffset="0" />
  <simplelinesymbol color="0x448ccb" alpha="0.8" width="2"/>
    </symbols>
</configuration>
Oranous,
   So did you copy the IdentifyWidget.swf and .xml to your widgets folder in your compiled Flex Viewer location? Error 2036 means it can not find the file.
OranousDanandeh
yes is did.  I created a folder called Identify under Widgets folder and copied the the two files you specified.
OranousDanandeh
I left out the directory Identify in the path for the config and url files.
Thank you.  It is working now.
Oranous
