Identify Widget question: Result Order
1765
08-22-2012 02:08 PM
KAnderson
Robert, thank you for the Identify Widget.
I'm using 3.0, and was wondering what order layers appear in under Results. It doesn't seem to be from IdentifyWidget.xml or the general config file.
RobertScheitlin__GISP
K Anderson,
   The order of the returned results are not fixed as each map service that is identified is executed asynchronously and not synchronously so the order the results are returned can be random. Just the way that it is...
KAnderson
Alright. Thanks for explaining!
