Identify Widget Not Working
4623
10
09-30-2013 08:56 AM
GeorgeHaskett
I am using the Idendify Widget version 3.4.2 for the Viewer for Flex application and have used older version of this widget at a different job with out any issues.  However, at my new job I cannot seem to get the widget to work properly.  I have tried various options and still cannot get it to work.  After trying making variouis adjustments I am officially at a loss.
My symptoms include the following:
Widget fails to identify features - acts as if it completely stopped working as there are no error or result messages/warnings.
At one point I was able to get the widget to work when using the preview option of the Application Builder in a test map, however once I copied the files over to my pre-existing map they no longer worked.  However, the widget worked with the extent tool and not the mappoint tool, I actually received a "No Results Found" message when attempting the mappoint tool.  At one point I commented out all my references to popups hoping that this would work, but it didnot.
I have even attempted added both a mapserver and featureserver and am still at a loss.
I have redownloaded the latest version (3.4.2) and copied the compiled version over and rebuilt from scratch using XML Notepad program.
Any help would be greatly appreciated.
I have attached my xml docs.
Haskett
RobertScheitlin__GISP
George,
   I believe that I fixed the reference attribute issue in version 3.5.1.
