Identify Widget Not Appear since upgraded to ArcGIS Viewer for flex 3.1
1283
6
03-12-2013 10:39 AM
ErinGrimm
I have been unable to get the identify widget tool to appear since upgrading to 3.1. Here is my config file.[ATTACH=CONFIG]22553[/ATTACH]
AnthonyGiles
Honored Contributor
Erin,
The identify tool is not an out of the box widget, have you downloaded the widget:
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
Regards
Anthony
ErinGrimm
Yes, I have downloaded the widget. It worked fine in 3.0 but i wanted to updgrade to viewer for flex 3.1 so I could take advantage of the updates of the identify widget. I updated both to 3.1 versions and it no longer appears.
AnthonyGiles
Honored Contributor
Your config file looks correct do you get any error message when you try and open the widget.
ErinGrimm
I get zero errors...
MichaelVolz
Esteemed Contributor
Do you have any troubleshooting software such as Fiddler or Firebug running when trying to access this tool to see if it reports any error information to you?
RhettZufelt
MVP Notable Contributor
You say you upgraded, did you happen to name it the same as the 3.0 version?
If so, there could be some "old" files in there that conflict.  Might try deleting the entire folder from your build path and re-build the project.
R_
