Identify Widget Issue for Layer in Cached Map Service
1567
05-10-2012 04:57 AM
LixinHuang
Hi Robert,
We tried to use your latest Identify Widget 2.5.7 to identify the parcel boundary layer. It seems to us that it did not work on the layer in cached map service. Could you please give us some suggestions on what could be wrong? We appreciate your help very much.
Update:
I just used Firefox with Firebug to view our Flex Viewer application. It was found the parcel boundary was identified by your widget. However, the InfoWindow was not popped up. I can use your widget to identify the other layers which are not in cached map services. I revert your widget back to 2.5.5. The widget worked for the parcel boundary layer in the cached map service. Any ideas?
RobertScheitlin__GISP
Lixin,
   Is the Map Service you are talking of publicly available so I can test against it? There were several changes concerning scale dependent and group layers for 2.5.5 to 2.5.7. Is this map layer inside it's visible scale range when you attempt to identify it?
LixinHuang
Robert,
Thanks for your reply. My map application is not publicly available. The parcel boundary feature class is not in a layer group in MXD. There is a scale dependency for that feature class. The  map service which includes the parcel boundary feature class is cached. I tried your Identify widget 2.5.5 with the same layer. It works.
Lixin,
  I got the fact that it works in the older version as I would expect it to, I need to figure out what is preventing it from appearing in the latest version. What is the min and max for the scale on this layer? Are you using the compiled version or the source code?
LixinHuang
Robert,
The Minimun Scale is 9029 and Maximu Scale is 0. The spatial reference is 102100. I am using the compiled version. Thanks.
Lixin,
   Don't forget to mark this one as answered.
