Identify Widget for FlexViewer 2.1
106576
266
09-23-2010 11:34 AM
RobertScheitlin__GISP
All,
   I have been waiting for the Final release of the FlexViewer 2.1 before I started to push out some widgets I have been working on.
Here is my Identify Widget for Flex Viewer 2.1. I have tested to ensure proper functioning with FlexViewer 2.1 and am now releasing it to you since the API Team did not get one into the FlexViewer.
Here is the link:
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
More FlexViewer 2.1 widgets to come stay tuned...
Will,
   I am looking at updating based on Erwan's and Ernst's suggestions. Not sure I will go down Erwan's suggestion of having a image and hyperlink though as that would require updating the InfoPopupWidget as well. But I am looking at the prefix and suffix on the hyperlink.
MelissaJohnson
Awesome as usual Robert!  Thank you!!
ShannonMartel
Great widget!  I have one question.  I am getting duplicate results.  Do you have any idea why?  Thank you for posting this widget.
Never mind, I figured it out my mistake.  Thanks!
Shannon
MarcWeinshenker1
Shannon
Can you share your solution?  I'm having the same problem.
ErwanCaradec
Hi Shannon,
we had the same problem in previous version because identifyWidget return one result for the group layer and a second result for the sub layer, it may be the same problem ?
I haven't my ArcGIS server at home so i can't reproduce the problem.
Look around this post :
http://forums.esri.com/Thread.asp?c=158&f=2421&t=299664
Erwan,
   Strange that I don't see the duplicate result issue and I have lots of grouped layers in my services... I wonder If I should look at adding your solution for that issue? It would be nice if I could duplicate the issue some are seeing with this.
WillHughes1
Robert,
How can I edit the mxml file so that the identify tool only identifies one layer?
Thanks.
Will
ErwanCaradec
Ok,
i can't reproduce the problem with the sample server on arcgisonline. I'll try later with my own server (on local network) and feed you back if necessary.
Regards
Erwan
Will,
   Do you mean one MapService or on layer in a MapService?
WillHughes1
One layer in a mapservice.
