Identify Widget for Flex Viewer - No Loading of Results in Application Preview
10794
26
02-13-2014 12:09 AM
RichardGeoghegan
I have added the Identify Widget found at the following address;
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
I have loaded two features into this tool in Widget settings and I chose the same URL for both of the feature layers which are found on my ArcGIS Server site. These are the same URLs I provided when adding these features as operational layers when beginning the Application Builder. When I preview my application the Identify Widget appears however when I click on one of the features which I added to the widget no results are loaded.
Any ideas as to what might be the issue?
RichardGeoghegan
I'm unable to save this setting, when I change it to 'Off', click 'OK' and go back into the setting it is switched back to 'On'.
This is odd because I can change the 'Open at start' to On or Off and it saves with no problem.
RobertScheitlin__GISP
Richard,
   OK, that is definetly a bug in the GUI. So you will have to do this manually (untill I get this bug fixed). To do this manually just open the IdentifyWidget_#.xml in a text editor program like notepad and find this line:
<layers onlythese="true">
and change it to false
<layers onlythese="false">
save your edit and clear your browsers cache and try to identify again.
RichardGeoghegan
OK and can you recommend which browser cache I should clear?
Richard,
   What ever browser that is your computers default browser.
RichardGeoghegan
I still have no luck. I changed this code in IdentifyWidget_2.xml and cleared Mozilla Firefox cached web content. I then loaded my application viewer on this browser but the identify doesn't load any results.
I checked the widget settings and 'Only These Layers' is still switched on which is expected?
Richard,
   As long as IdentifyWidget_2.xml is the highest numbered xml in your Identify folder and you open it and the onlythese is false then you have sucessfully accomplished the test I wanted you to do. Short of all this, I am drawing a blank as to why your data is not returning any results. Is this sensitive data or is it something you can share with me for further testing? If you can export one of the layers out to a file geodatabase and zip that up it would help.
RichardGeoghegan
Thanks Robert I have attached one of these features in this Zip folder.
Richard,
   Hmm... Nothing good to report. I took your layer and published a map service from it trying to keep everything as close to your as possible, and I was able to identify the Green Coast Beaches with out any issue in the preview tab.
[ATTACH=CONFIG]31412[/ATTACH]
I have now tried it with the data in SDE and it work fine there as well. Can you provide the REST Service directory page for this layer, so that I can keep everything as close as possible.
  1. What version of ArcGIS Server are you on?
  2. What version of the ArcGIS Viewer for Flex are you using?
  3. What Version of the Identify Widget are you using?
RichardGeoghegan
Robert here is the REST Service information for the layer;
Layer: GIS.DBO.GreenCoastAwardBeaches (ID: 1)
Display Field: NAME
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description:
Definition Expression:
Copyright Text:
Default Visibility: true
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Has Labels: false
Can Modify Layer: false
Can Scale Symbols: false
Extent:
XMin: 33613.596400000155
YMin: 24752.553899999708
XMax: 351168.4704999998
YMax: 447801.0862000007
Spatial Reference: 29900  (29902)
Drawing Info:
Renderer:
Simple Renderer:
Symbol:
Style: esriSMSCircle
Color: [76, 230, 0, 255]
Angle: 0.0
XOffset: 0
YOffset: 0
Outline:
[0, 0, 0, 255] Width: 1
Label:
Description:
Transparency: 0
Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field: null
Fields:
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
Id ( type: esriFieldTypeInteger , alias: Id )
NAME ( type: esriFieldTypeString , alias: NAME , length: 50 )
COUNTRY ( type: esriFieldTypeString , alias: COUNTRY , length: 50 )
LOCATION ( type: esriFieldTypeString , alias: LOCATION , length: 50 )
PROVINCE ( type: esriFieldTypeString , alias: PROVINCE , length: 50 )
GC_11 ( type: esriFieldTypeString , alias: GC_11 , length: 50 )
GC_10 ( type: esriFieldTypeString , alias: GC_10 , length: 50 )
Awarded_11 ( type: esriFieldTypeString , alias: Awarded_11 , length: 50 )
Awarded_10 ( type: esriFieldTypeString , alias: Awarded_10 , length: 50 )
WEB_PAGE ( type: esriFieldTypeString , alias: WEB_PAGE , length: 250 )
GC_12 ( type: esriFieldTypeString , alias: GC_12 , length: 50 )
Awarded_12 ( type: esriFieldTypeString , alias: Awarded_12 , length: 50 )
GC_13 ( type: esriFieldTypeSmallInteger , alias: GC_13 )
Awarded_13 ( type: esriFieldTypeString , alias: Awarded_13 , length: 10 )
Shape ( type: esriFieldTypeGeometry , alias: Shape )
Here are my versions information;
ArcGIS 10.1 SP1 for Server
ArcGIS Viewer for Flex version 3.6
Identify widget 3.6.3
Richard,
   Does your REST Service directtory for the whole map service (not a specific layer) have the link at the bottom of the page for Identify?
Beaches/Beaches (MapServer)  View In:   ArcGIS JavaScript   ArcGIS.com Map   Google Earth   ArcMap   ArcGIS Explorer
View Footprint In:   ArcGIS.com Map
Service Description: Beaches
Map Name: Layers
Legend
All Layers and Tables
Layers:
  • GIS.DBO.GreenCoastAwardBeaches (0)
Description:
Copyright Text: Richard Geoghegan
Single Fused Map Cache: false
Initial Extent:
  • XMin: 17735.852695000158
  • YMin: 3600.1272849996385
    XMax: 367046.2142049998
    YMax: 468953.5128150008
Full Extent:
  • XMin: 33613.596400000155
  • YMin: 24752.553899999708
Units: esriMeters
Supported Image Format Types: PNG32,PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,BMP
Document Info:
  • Title:
  • Author:
    Comments:
    Subject:
    Category:
    Keywords: Irish Beaches
    AntialiasingMode: None
    TextAntialiasingMode: None
Supports Dynamic Layers: false
MaxImageHeight: 4096
MaxImageWidth: 4096
Min Scale: 0
Max Scale: 0
Child Resources:   Info
Supported Operations:   Export Map   Identify   Find   Return Updates
