Identify Widget for Flex Viewer - No Loading of Results in Application Preview
10771
26
02-13-2014 12:09 AM
RichardGeoghegan
I have added the Identify Widget found at the following address;
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
I have loaded two features into this tool in Widget settings and I chose the same URL for both of the feature layers which are found on my ArcGIS Server site. These are the same URLs I provided when adding these features as operational layers when beginning the Application Builder. When I preview my application the Identify Widget appears however when I click on one of the features which I added to the widget no results are loaded.
Any ideas as to what might be the issue?
RobertScheitlin__GISP
Richard,
   I just tested version 3.6.3 in App Builder and it work fine in the preview Tab. Is it just the preview tab? Does it work when you use the actual configured application? One thing to note is Flex is a case sensitive language so if you added your operational layers using a certain CaSe then you have to add that eXaCt case when configuring the layer in the identify widget GUI.
RichardGeoghegan
Robert it doesn't work in the configured application either. It must not be an issue with case differences either as the link I chose when loading the operational layers is the same in terms of case as the URL I chose in the widget settings.
There is one thing that concerns me is that the layers that I published to ArcServer were from an SDE database. This hasn't caused any problems when implementing the feature layers to the default widgets, could that be a possible cause of the problem in the identify widget?
Richard,
   No, This widget has been around for years and 1000 of users are using SDE data. It is something in your configuration. It is just hard for me to say what. Can you zip up the main config.xml and your IdentifyWidget_#.xml (the one with the highest number) and attach it for me to review? The normal location to find these files would be "c:\inetpub\wwwroot\YOUR APPLICATION NAME\"
RichardGeoghegan
Robert here are those files. Thanks
Richard,
  Well, case was not the issue as you said. There is nothing jumping out at me either.
  1. Are these layers visible when you attempt to identify them?
  2. What is the type of geometry for these layers?
  3. Can you possibly do a screenshot of the REST Service directory page for layer id 0 'BlueFlagBeaches'? Or just copy the text and paste it into a text file and zip it.
RichardGeoghegan
Yes, these layers are visible when I attempt to identify them and they are point features. I attached the REST URL, is this correct?
Richard,
   No that is not what I was looking for. This is what I was looking for
Layer: Schools (ID: 0)  Name: Schools
Display Field: SCHOOLNAME
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description:
Definition Expression: N/A
Copyright Text:
Default Visibility: false
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Has Labels: false
Can Modify Layer: false
Can Scale Symbols: false
Use Standardized Queries: true
Extent:
  • XMin: 604569.1675482318
  • YMin: 1123900.0551555306
    XMax: 730448.9172974639
    YMax: 1247514.7957506552
    Spatial Reference: 102629  (102629)
Drawing Info:
  • Renderer:
    • Unique Value Renderer:
    • Field 1: DISTRICT
      Field 2: null
      Field 3: null
      Field Delimiter: ,
      Default Symbol:
      • N/A
      Default Label: null
      UniqueValueInfos:
      • Value: CALHOUN COUNTY
      • Label: Calhoun County
        Description:
        Symbol:
    Transparency: 0
    Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeNone
Type ID Field: null
Fields:
  • OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
  • SCHOOLNAME ( type: esriFieldTypeString , alias: SCHOOLNAME , length: 50 )
  • STREET_NUM ( type: esriFieldTypeDouble , alias: STREET_NUM )
  • STREET_NAM ( type: esriFieldTypeString , alias: STREET_NAM , length: 35 )
  • CITY ( type: esriFieldTypeString , alias: CITY , length: 16 )
  • STATE ( type: esriFieldTypeString , alias: STATE , length: 2 )
  • ZIPCODE ( type: esriFieldTypeString , alias: ZIPCODE , length: 5 )
  • PHONE ( type: esriFieldTypeString , alias: PHONE , length: 12 )
  • NCES_ID ( type: esriFieldTypeString , alias: NCES_ID , length: 15 )
  • STATE_ID ( type: esriFieldTypeString , alias: STATE_ID , length: 12 )
  • DISTRICT ( type: esriFieldTypeString , alias: DISTRICT , length: 20 )
  • SHAPE ( type: esriFieldTypeGeometry , alias: Shape )
  • ccDistrict ( type: esriFieldTypeString , alias: Calhoun County School District , length: 25 )
Supported Operations:   Query   Generate Renderer   Return Updates
RichardGeoghegan
Sorry about that, here it is.
Richard,
   Hmm... this is perplexing. can you go back into the identify widget GUI and change the "Only These Layers" to "Off" and try to identify again.
