Identify Widget 3.6.1 can not add layers,
1866
01-14-2014 06:10 AM
KimBülow
When I try to add layers and inclueded all fields and hit add search button that was turned blue when the fields were added, which worked in version 3.5 if I press ok, it has not been saved indentify layer. and when checking the layer again in the Identify Widget is empty.
If I add a exclude layer, I can save, but the next thing I try to edit the widget, I get the error "Error # 1010"
Is someone who can help
I use the compiled version 3.6.
Identify Widget version 3.6.1 for Flex Viewer 3.6
[ATTACH=CONFIG]30487[/ATTACH]
RobertScheitlin__GISP
Kim,
   3.6.2 available now fixes that issue.
Kim,
   I can reproduce the issue and will begin working on the bug as soon as possible.
Kim,
KimBülow
Kim,
Thanks it works now. It is excellent widgets you're doing.
