Identify Widget 2.5 - Cached v Dynamic Services
1601
08-29-2012 07:57 AM
SimonMorris
I am implementing Robert Scheitlin's Idenitfy Widget (v2.5) and have been unable to access data from a cached map service. But if I load that service dynamically the widget works perfectly. Has anyone else had his problem and if so is there any trick or workaround to enable the widget to access data in cached services? I noticed in the text file that comes with the widget that version 2.5.8 has fixed the "cached/tiled layers not returning identify results" issue but for some reason I'm not able to get the widget working with a cached service.
Any help would be greatly appreciated! Thanks!
