Robert,
I checked the parcel feature class and property table and found that there is a join between them. There is a total of more than 130 fields in the joined attribute table. The feature class and table is on ArcSDE geodatabase. It was also found that a relationship class was created between them. I copied the feature class and table into a file geodatabase without any relationship class created. I kept the join between them and publised the map service based on the new file geodatabase. I tried to use the Enhanced Identify Widget you develoepd against this new map service. It worked perfectly. I am guessing the relationship class may create the issue I encountered. Anyway, thanks for all your help and the great widgets you developed.
