Identify Widget 2.2.2 Not Returning Results
2546
03-02-2011 09:55 AM
EricVenden
Robert,
I'm having problems configuring the latest Identify Widget (2.2.2).  I am using the compiled version and have updated the swf and the xml.  The xml now includes the following line at the top of the file-before the layer tags:
<returngeometryforzoom>true</returngeometryforzoom>
I also tried adding the above line in each layer tad.
I cannot get the Identify tool to return any results.  There is no error, it simply returns a box with the title of the layer I have clicked on.
I looked in the XML config help file and could not see any mention of defining this for each layer.
Has anyone else experienced issues?
Thanks for your time.
Eric V
Gurnee, IL
RobertScheitlin__GISP
Eric,
  Which compile version the FV2.1 or 2.2?
EricVenden
Robert,
I'm using 2.2
Thanks
Eric
Eric,
I think that I might have a bad compile of the FV2.2 version, but just to check can you change the IdentifyWidget.xml
<layers onlythese="true">
Eric,
   I do believe there was an issue in the 2.2 compiled swf, so I put out a new 2.2.2f version of the download. Give that one a spin.
EricVenden
Robert,
That did it.  Thanks for the quick response.
Eric
