Identify Tool 3.6.7 - Problem with fields displaying in results window.
3790
10-23-2014 12:43 PM
Scott_Russell
Hello,
We are using the Identify Tool 3.6.7 on AppBuilder 3.6.   We set-up a table in the Identify tool interface and only half of the fields are expressing results.  We cannot figure out why the other field are being prevented from producing results.  Any idea what could be causing this?  We have changed aliases, recreated the MXD, republished the service, everything we can think of and can't isolate the issue.
Please help.
Scott from SWSC
RESOLVED
RobertScheitlin__GISP
Scott,
   Do you have the Replace Nulls With Empty String set to true? and if so are those fields null?
Scott_Russell
This is resolved.  We changed aliases without rebuilding the the MXD from scratch.  Once we created a new MXD and re-symbolized the tables everything worked out.
