Identify Popup & alpha value
1325
05-28-2012 02:55 PM
ChristinaLaurier
I am using the FlexViewer sample v2.5.
I have downloaded the IdentifyWidget v 2.5.8; I would like to switch the background alpha of the pop-up display (the one that opens when you mouse over the results state).  However, I can't seem to find the proper spot to change this?
I have tried several spots throughout the IdentifyWidget.mxml and the PopUPRendererSkin.mxml but had no luck. I know it's easy, just having trouble narrowing down the proper alpha value to change.
RobertScheitlin__GISP
Christina,
   You will need to change the alpha of the map.infoWindow as that is the parent of the popup. You can add this line to the showHighlight function.
map.infoWindow.alpha = 0.4;
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Christina,
ChristinaLaurier
Thanks as always Rob!
