Identify 3.1.1 not returning layer info when zoomed in
871
01-23-2013 08:19 AM
PeterHoffman
Robert,
I have several layers that I am listing in the identifywidget.xml and one of them (Section Notes) does not display when I am zoomed in more that its visible scale range. I have set <identifylayeroption>all</identifylayeroption> and the results work when I am zoomed out to the visible range.
Why is this happening?
Thanks.
<?xml version="1.0" ?>
<configuration>
<identifytolerance>5</identifytolerance>
<defaultzoomscale>5000</defaultzoomscale>
<keepidentifyactive>true</keepidentifyactive>
<returngeometryforzoom>true</returngeometryforzoom>
<enablelineselect>true</enablelineselect>
<enableextentselect>true</enableextentselect>
<enablepolyselect>true</enablepolyselect>
<enablemouseovergraphicsinfo>false</enablemouseovergraphicsinfo>
<enablemouseoverrecordinfo>false</enablemouseoverrecordinfo>
<usemaptime>false</usemaptime>
<infoautoclosemilliseconds>2000</infoautoclosemilliseconds><!-- 2 seconds -->
<autoactivatedtool>mappoint</autoactivatedtool><!-- possible values are extent or polygon or mappoint or polyline or nothing -->
<excludebasemaps>true</excludebasemaps>
<disablepopuplinks>false</disablepopuplinks>
<labels>
  <zoom2message>Click to Zoom to Point</zoom2message>
  <identifylabel>Identify</identifylabel>
  <resultslabel>Results</resultslabel>
  <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel>
  <pointlabel>Identify by Point</pointlabel>
  <linelabel>Identify by Polyline</linelabel>
  <rectlabel>Identify by Rectangle</rectlabel>
  <polylabel>Identify by Polygon</polylabel>
  <clearlabel>Clear</clearlabel>
  <loadinglabel>Loading...</loadinglabel>
  <removeresultmessage>Remove Result</removeresultmessage>
  <idfrom>Identify From</idfrom>
  <noresultsfoundlabel>No Results Found</noresultsfoundlabel>
  <resultsfoundlabel>Results Found</resultsfoundlabel>
</labels>
<useproxy><!-- Enter the label of the MapService from the main config.xml -->
  <!--<proxymapservice label="Imagery" />
  <proxymapservice label="Streets" />-->
</useproxy>
<layers onlythese="true">
     <layer>
   <name>Parcels</name>
   <fields all="false">
    <field name="PARCELID" alias="Parcel ID" />
    <field name="STREET" alias="Street" />
    <field name="MAIL_ZIP" alias="ZIP Code" />
    <field name="OwnerName" alias="Owner Name" />
   </fields>
   <links>
    <link includeinresults="false" field="" alias="">
     <linkprefix></linkprefix>
     <linksuffix></linksuffix>
     <iconfield></iconfield>
     <iconprefix></iconprefix>
     <iconsuffix></iconsuffix>
    </link>
   </links>
   <zoomscale>15000</zoomscale>
   <forcescale>true</forcescale>
  </layer>
  <layer>
   <name>Section Notes</name>
    <field name="NOTES" alias="Comments" />
   </fields>
   <links>
    </link>
   </links>
  </layer>
<layer>
   <name>General</name>
    <field name="HDREFNO" alias="HDREFNO" />
    <field name="WATERSUPPLY" alias="Water Supply" />
    <field name="SANITARYTYPE" alias="Sanitary Type" />
    <field name="APPLICANT" alias="Applicant" />
    <field name="COMMENTS" alias="Comments" />
   </fields>
   <links>
    </link>
   </links>
  </layer>
</layers>
<symbols>
     <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid">
      <outline color="0x448ccb" alpha="0.8" width="2"/>
     </simplefillsymbol>
     <simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0">
      <outline style="solid" color="0xffffff" alpha="0.8" width="1"/>
     </simplemarkersymbol>
     <picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0" />
  <simplelinesymbol color="0x448ccb" alpha="0.8" width="2"/>
    </symbols>
</configuration>
RobertScheitlin__GISP
Peter,
This is the designed behavior of the widget... If the layer is not visible why would you want results for it?
PeterHoffman
The layer is also used in one of 2 editing widgets and I do not want if in range when I am in the other editing widget. I am returning attributes from a field and I am zoomed in to the middle of a large polygon so you will not see the borders of the polygon. In your application you have the tag of <identifylayeroption> with the possibility of top, visible or all. It is not identifying even when I use the all option.
PeterHoffman
I ended up adding the layer in another map service and that works when I zoom in.
The first one was also a feature service and I did not want if visible at a certain scale.
