ICONFLD-Revisted
1365
06-26-2014 08:32 AM
EricVenden
Good monring all (specifically Robert :),
Several years ago, ran into a limitation of the eSearch and Identify widgets where the link icon could not be changed based on the type of document being linked to.  At the time I had to add a text field (ICONFLD) that could not be null, but need not contain values.
Has this been fixed?  I may have missed a post along the way or failed to thouroughly read the readme file with the widgets.
Here's a link to original thread:
http://forums.arcgis.com/threads/21377-Change-link-icon-in-Identify-widget-in-flexviewer-2.2
Thanks for your time
Eric V
Gurnee, IL
RobertScheitlin__GISP
Eric,
   Help me remember your use case. Currently for each layer you configure in the Identify widget you can specify a icon to be used for the link by either using the iconfield and/or the iconprefix and/or iconsuffix. Specifying one or more or all of those allows you to set the icon image to be used for all links on that layer. If you want a different icon based on the specific feature of that layer then you have to use the iconfield to do that.
Eric,
EricVenden
Thanks Robert,
I believe my issue from 2011 (FV 2.2) have been fixed (or I am doing it properly now).  I am ONLY using the <iconsuffix> tag now - I do not configure the <iconfield> tag.
Eric V
Eric,
  OK glad it is working for you.
