Hyperlink widget
1660
02-05-2013 06:53 AM
NinaRihn
is there such a thing as a widget I can put in the widget container that you can click to simply open and external file or website?   I currently have my "help" as a static image widget, but if I want to place the widget icon with the other icons, the user has to click it to open the Help widget, then click the help widget again to open the actual Help html file.
RobertScheitlin__GISP
Nina,
   Sure it is called the link widget:
http://www.arcgis.com/home/item.html?id=5e4717fe1bb247f89b9092308e569c30
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
Nina,
NinaRihn
Thank you!! that is awesome and exactly what I need.   I noticed on your sample view of the application yours was a dropdown list of links, which would be really nice or something else I want to do.    How can I make that happen?    Otherwise, I can live with individual icons..     thanks, as always for your great widgets and presence in the forums..
Nina,
   An example of how to configure that is in the download. It is called config-link.xml.
Don't forget to mark the thread as answered as indicated in my previous post.
NinaRihn
You have heard this before, but you ROCK!
