how to find or query on a field from multiple feature classes
820
02-01-2013 11:01 AM
StephenNorris
I just started using the flex viewer. previously I used the ArcGIS server manager app builder and could create a find or query that used the same number ID field from three FCs of different geometry (point, line, polygon).
I only seem to be able to pick one FC for an attribute search. the query widget specifies that it can only be used on one layer, so i was hoping the find widget would have the ability to use more than one FC.
Steve
RhettZufelt
MVP Notable Contributor
Steve,
You might look at the single line search in the headercontrollerwidget:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Header_Controller_widget/01m300...
R_
