Hyperlink Logo in config.xml?
1946
9
02-08-2012 11:59 AM
AshleyPeters
Is it possible to make the logo in the config.xml a hyperlink?
RobertScheitlin__GISP
Ashley,
   OK, then this is what you need to add to the HeaderControllerWidget.mxml:
  1. Just add this to the top where the other private vars are:
    private var linkURL:String;
  2. In the widgetConfigLoadedHandler funtion add these lines in the if configXML:
                        linkURL = configXML.logolinkurl;
  3.                     if (linkURL)
                            logoIcon.buttonMode = true;
                            logoIcon.useHandCursor = true;
                            logoIcon.addEventListener(MouseEvent.CLICK, img_clickHandler);
  4. Then add this new function:
                private function img_clickHandler(event:MouseEvent):void
  5.             {
                    navigateToURL(new URLRequest(linkURL));
Next add this line in the HeaderControllerWidget.xml:
<logolinkurl>http://www.esri.com</logolinkurl>
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
Ashley,
   It is possible if you can edit the HeaderControllerWidget.mxml. DO you have the ability to edit the source code?
AshleyPeters
Yes, I'm using FlashBuilder.
Ashley,
  3.                     if (linkURL)
  5.             {
AshleyPeters
Thanks Robert!
ShaneCarey
This is really great and very useful. I was wondering would it be possible to add a label to the hyperlink as you hover over the logo with your mouse.
Thanks
ShaneCarey
Thanks
Shane,
  Sure all you need to do is add this line to the others:
                    linkURL = configXML.logolinkurl;                     if (linkURL)                     {
                        logoIcon.toolTip = "Blah blah blah";                         logoIcon.buttonMode = true;                         logoIcon.useHandCursor = true;                         logoIcon.addEventListener(MouseEvent.CLICK, img_clickHandler);                     }
AnthonyGiles
Honored Contributor
All,
If you dont have the ability to edit the source code you can always hide the logo and use the static image widget instead:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Static_Image_widget_tags/01m300...
Regards
Anthony
ShaneCarey
Great stuff, thanks.
