How to use specify points or comma as a thousand separator in the flex viewer.
1106
12-17-2013 08:04 AM
JuliaGalindo
I am using the 3.5 Flex viewer version and defining the popups to a flex project, I know it is possible to set the number format on and use the thousand separator. But I can???t find a way to specify if it should be a point or a comma.
I have the same problem to percentage even though it was defined in ArcMap to be shown as a percentage, in the flex viewer it does not respect it and there is no way, at least I haven???t find it, to set it.
Thank you for the help!
Julia
JuliaGalindo
For those like me, in the flex viewer settings, advance settings, the locale should be English-English in order to have comma as a thousand separator.  I am in Central America, and I had selected Spanish, thinking only in the language preference.  My mistake was to think that is was referring to the application builder language, and in deed it does, but it also refers to the regional configuration.
RobertScheitlin__GISP
Julia,
   Based on the fact that your viewer seems to think it is in some other locale, I recommend that you contact Tech Support and get them to help with your issue.
JuliaGalindo
Thanks for the quick reply, I checked the computer settings and they seem to be ok, in the right place. Anyway I will double check with someone from support.
thanks !
JuliaGalindo
DavidMarroquin
Julia, thanks for your answer, it was useful for me.
