How to show multiple infowindow at the same time?
1170
03-09-2011 07:23 PM
jianhuizhou
Hi,everyone
How to show multiple infowindow at the same time?Now if you show the second infowindow the first one will hide.Have any idea to show them at the same time?
RobertScheitlin__GISP
jianhui,
   The map is only allowed to have one info window (singleton design).
Hernando_CountyProperty_Apprai
Add a new object as type InfoWindow as follows:
[INDENT]var callout:InfoWindow = new InfoWindow(map);[/INDENT]
Then set the properties of the InfoWindow.  In the following example the header of the InfoWindow is "Test" and the content is a TextArea that has the text "This is my test"
[INDENT]callout.label = "Test";
var calloutText:TextArea = new TextArea();
calloutText.editable = false;
calloutText.text = "This is my test";
callout.content = calloutText;[/INDENT]
Now make your new InfoWindow visible and place it where the user clicked:
[INDENT]callout.setVisible(true,false);
var position:MapPoint = event.graphic.geometry as MapPoint;
callout.show(position);
[/INDENT]
Now add it to the map:
[INDENT]map.addChild(callout);[/INDENT]
