How to prevent date change the time zone
2425
05-07-2013 07:44 AM
JulieYuan
I have a Date column (without time), at Eastern Time Zone.
The pop up converted the Date automatically. For example, our date is May 07, 2013, the pop up will show as "May 06, 2013 08:00PM".
I don't want the system convert the date to UTC.
Which Field or Tag can I use?
Thanks.
AnthonyGiles
Honored Contributor
Julie,
The useutc attribute needs to be added to your format tag and set to false:
<fields>
     <field name="TRACK_DATE">
        <format dateformat="longDate" useutc="false"/>
    </field>
</fields>
See the help file here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Pop_up_configuration_files/01m3...
Regards
Anthony
AnthonyGiles
Honored Contributor
Julie,
<fields>
    </field>
</fields>
Regards
Anthony
JulieYuan
Anthony,
Thanks for anwsering my question. It works.
Best Regard,
Julie
AnthonyGiles
Honored Contributor
Julie,
Glad you got it working, please do not also forget to mark the post as answered by also checking the tick on the correct answer.
Regards
Anthony
