how to make arcgis flex app zoom in and zoom out with out navigation panel
1364
08-23-2014 04:19 AM
MadhavaraoChennupati
hi gud evenig to every one. i am facing some problem with arcgis for flex viewer application. the application is not zoom in and zoom out when i am using in touch screens with out navigation panel. so how to make application zoom in and zoom out with fingures touch with out using zoom in and zoom out buttons
RobertScheitlin__GISP
Madhavarao,
   I just tested on my Android 4.0.3 tablet with Flash Player 11.1 and I can not get the Viewer or any of the API Samples to pinch zoom or rotate the map. I am only able to pan. Maybe Bjorn Svensson‌ can shed some light on this.
BjornSvensson
Madhavarao Chennupati‌ - what device are you testing on, what OS, and what version of the Adobe Flash Player?
hi i am using adobe flash player 14 OS is windows 8 working on my laptop
BjornSvensson
Multi-touch gesture support on different devices is not implemented as standard as it should be.
I have tested it successfully on some Windows 7 and 8.1 machines (in both Firefox and IE11), but on some devices only single-touch gestures seemed to work for the Flex applications:
  • an old Microsoft Surface Pro
  • HP TouchSmart
What sort of laptop are you using?
Does any of these work for your specific device:
  • Double-click map to recenter and zoom in at clicked location. To zoom out, press Alt when double-clicking (doubleClickZoomEnabled).
  • Pinch open to zoom in. (Only works with Flash Player 10.1 or above)
  • Pinch close to zoom out. (Only works with Flash Player 10.1 or above)
  • Two-finger tap to zoom out. (Only works with Flash Player 10.1 or above)
API Reference: com.esri.ags.Map
Basic apps to test:
