How to add uncompiled widgets to Flex Projects
1231
01-09-2013 12:01 AM
IFTIKHARALI
When i add the uncompiled Selection widget to my Flex Builder Project , developer flex viewer and  then compile the project it shows 19 errors and all most all are " Could not resolve <viewer:transitions> to a component implementation. " how to resolve this error please guide me.
Thanks in advance.
EricVenden
When setting up your FB Project, did you follow the instructions here?
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Getting_started_for_developers/...
Also, you need to add each module (the path to each widget mxml) under the project properties (Flex Modules).
Hope this helps.
Eric V
IFTIKHARALI
Dear i followed the instructions but still the problem is there.
EricVenden
I have a few questions:  What version of FlashBuilder are you using?  What SDK are you using?  What version of the FlexViewer are you using?
Thanks
Eric V
