How to add the ???scale text??? on the map?
5654
6
12-27-2012 10:20 PM
JamalNUMAN
Legendary Contributor
I???m wondering if there is a way to add the ???scale text??? on the map such that the scale of the map is shown at each zoom.
[ATTACH=CONFIG]20238[/ATTACH], [ATTACH=CONFIG]20239[/ATTACH]
In particular cases, the ???scale bar??? is not sufficient to identify all the required issue and thus the ???scale text??? is needed all the time. It is very basic element for any map.
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: ericv
Jamal,
I've added this to our app, but we are not using the Application Builder (we use Flash Builder)
In the mxml file (CoordinateWidget.mxml), there is a map_mouseMoveHandler function.
In the "original" file, there is a line in this function that reads:
                coords.text = m_func(mapPoint);
This needs to be changed to:
                coords.text = m_func(mapPoint)+"          Scale 1:" + map.scale.toString();
Not sure this will help you much unless you have FB.
Eric V
Gurnee, IL
by Anonymous User
Not applicable
Jamal,
Eric V
Gurnee, IL
ronaldmcfarlane
As EricV stated, you will need FashBuilder to modify the CoordinateWidget.mxml file to add the scale value.  I use a bit more code than EricV does, because I want the scale to be an integer value and to change as the various mouse actions change.  Below are three code fragments that may help.  (I use comments to help me track changes and give me a place to start when the next version of a widget or Flex is released.)  Hopefully this helps.  (Note: the code below is for flex viewer 3.1 and FlashBuilder 4.7.
// - Start modification - //
[Bindable]
private var mapScale:int;
// - End modification - //
map.addEventListener(MouseEvent.MOUSE_MOVE, map_mouseMoveHandler);
map.addEventListener(MouseEvent.MOUSE_WHEEL, map_mouseMoveHandler);
map.addEventListener(MouseEvent.DOUBLE_CLICK, map_mouseMoveHandler);
// - end modification - //
private function map_mouseMoveHandler(event:MouseEvent):void
var nf:spark.formatters.NumberFormatter = new spark.formatters.NumberFormatter
const mapPoint:MapPoint = map.toMapFromStage(event.stageX, event.stageY);
mapScale = Number(map.scale);
coords.text = m_func(mapPoint) + "     Scale 1:" + mapScale;
by Anonymous User
Not applicable
Original User: [email protected]
[Bindable]
[ATTACH=CONFIG]20271[/ATTACH]
Thank you Eric and Ronald for the help.
�?� I searched all my C drive but couldn�??t find the �??CoordinateWidget.mxml�?�
�?� I�??ve Adobe Flash Builder 4 installed
�?� I�??ve the ArcGIS Viewer for Flex 3.1 installed
Could you please indicate how can I proceed now?
ronaldmcfarlane
You will need to download the source code and API for Flex.  The following link will walk you through the process: http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Getting_started_for_developers/...
by Anonymous User
Not applicable
Many thanks Ronald.
I�??ll see if I can manage this issue knowing that I�??m not a developer! Should I be?
Best
Jamal
EricVenden
If you can follow directions, you can do it Jamal.
