How to add current date to config.xml
2623
7
07-21-2011 09:54 AM
RuyMartinez
Hello Everyone,
I am attempting to add the current date and add it to a query in the config.xml file for the flex viewer.
This works without any problems:
<layer label=???My Date Layer??? type=???feature??? visible=???true??? url=???http://server/arcgis/rest/services/datelayer/FeatureServer/1??? definitionexpression=???date>=???07/21/2011??????/>
I'm looking for something like this:
<layer label=???My Date Layer??? type=???feature??? visible=???true??? url=???http://server/arcgis/rest/services/datelayer/FeatureServer/1??? definitionexpression=???date>=CURRENT_DATE??? />
Has anyone else done something like this?
Thank you,
Ruy
RobertScheitlin__GISP
Ruy,
   Have you tried GetDate()?
RuyMartinez
I've tried
<layer label=�?�My Date Layer�?� type=�?�feature�?� visible=�?�true�?� url=�?�http://server/arcgis/rest/services/datelayer/FeatureServer/1�?� definitionexpression=�?�date>=GetDate()�?�/>
<layer label=�?�My Date Layer�?� type=�?�feature�?� visible=�?�true�?� url=�?�http://server/arcgis/rest/services/datelayer/FeatureServer/1�?� definitionexpression=�?�date>='GetDate()'�?�/>
<layer label=�?�My Date Layer�?� type=�?�feature�?� visible=�?�true�?� url=�?�http://server/arcgis/rest/services/datelayer/FeatureServer/1�?� definitionexpression=�?�date>= + 'GetDate()'�?�/>
and
<layer label=�?�My Date Layer�?� type=�?�feature�?� visible=�?�true�?� url=�?�http://server/arcgis/rest/services/datelayer/FeatureServer/1�?� definitionexpression=�?�date>= + GetDate()�?�/>
None of these combinations work.
Ruy,
   What is the underling data for this featureService in (SDE SQL Server or Oracle, Shapefile, FDGB, what)?
RuyMartinez
SDE SQL SERVER
Ruy,
   OK, CURRENT_DATE keyword is suppose to be supported.
RuyMartinez
Robert,
I want to thank you for taking the time to help me out.  I'm still stuck on the syntax.  Here are the latest attempts
definitionexpression=�?�date>=CURRENT_DATE�?�
definitionexpression=�?�date>=CURRENT_DATE()�?�
definitionexpression=�?�date>= + 'CURRENT_DATE'�?�
definitionexpression=�?�date>= + 'CURRENT_DATE()'�?�
Do I have to format the date before I send it in the query?  I'm not sure what else to try.
Ruy
RuyMartinez
Okay I finally go something to work!
definitionexpression="date>= DATEADD(d, DATEDIFF(d,0,GETDATE(),0)"
I found the answer here
Thanks for your help on this Robert.
Ruy
