How to add copyright text in exported image using snapshot widget
1920
04-21-2012 04:17 AM
PankajChaudhari
Hi All,
I am using snapshot widget (from code gallery) for exporting current map into JPEG and PNG format.
I want to add copyright text in exported images.
Please guide me in the right direction.
Any help much appreciated.
Thanks in advance.
Best Regards
Pankaj
RobertScheitlin__GISP
Pankaj,
   For that you would have to extend Erwans' Snapshot widget to add the copyright text yourself. You would need to look into drawing a TextField to the BitmapData. Sorry I won't be writing this code for you, if you need this ability you will have to do it.
Pankaj,
   The latest version 2.5.1 of the copyright widget now has the copyright in the export automatically.
http://www.arcgis.com/home/item.html?id=3893f396489344aa9f8fcdef15b3fe1b
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
PankajChaudhari
Hi Robert,
Thanks for your immediate reply.
Copyright widget is really nice.
But as i mentioned earlier, i am using snapshot widget for exporting map. When i export complete map, then copyright information is appearing in exported map.
But when i select map area using rectangle tool (selecting certain portion of map), its not appearing.
My requirement is, i want copyright information in each exported map, irrespective whether its a complete map or some portion of map.
Please assist me.
Thanks a lot.
Best Regards
Pankaj
Pankaj,
PankajChaudhari
Hi Robert,
Thanks a lot for guiding me in right direction.
Best Regards
Pankaj
