Help with esearch Widget version 2.4
1601
6
06-22-2012 08:06 AM
AimeiChen
Hi, Robert
I am using your esearch widget version 2.4, everything works fine. I can search features and show results in grid then export them. Except when tried to do a spatial search and show reuslt in grid, the export button is missing. Would you please tell me how to add it to the grid?
Amy
RobertScheitlin__GISP
Amy,
   Attached is 2.4.0.14 source code.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Amy,
  I don't remember if that was something that was fixed in a release since 2.4, but I can't duplicate the issue in the latest version 3.0 of the widget (this is going to be your problem with not staying current, as I fix bugs and issues as the are pointed out but I don't go back and fix older versions).
AimeiChen
Amy,
I know that's my problem for not staying up-to-date. Would you please tell me which part of the source code I need to check with? thanks
Amy,
  Well that will be the problem, as that is so many versions and bug fixes ago I don't rememeber where in the code that is.
AimeiChen
Amy,
Thanks Robert. But, do you still keep your most up-to-date esearch widget version 2.4? If so, would you please share with me?
Amy
Amy,
AimeiChen
Amy,
Thank you so much Robert, Appreciated!
