help with ConfigManager
1203
03-20-2013 09:04 AM
CristianSepulveda_Melo
help with configManager.as
* configService_resultHandler private function (event: ResultEvent): void
******** try
************ / / parse main config configuration file to create data object
************ configdata configdata = new ();
************ var configXML: XML = XML (event.result);
************ configData.configXML = configXML;
I have a question regarding the value var configXML receiving the XML (event.result) that value is or where it gets?
that begins later assigned to another avariables
RobertScheitlin__GISP
Cristian,
   If you look at the code the function you are speaking of is configService_resultHandler(event:ResultEvent). So it is the result of a call to the HTTPService call in the loadConfig function.
Cristian,
ok thanks you're right
