Help with AGOL and Flex Viewer
1796
01-11-2013 06:59 AM
JosephNigro
I have been fooling around with ArGIS On-line and I've run into some dead ends, I think. I suppose in AGOL I can't sync the mouse movement with the data to perform a "mouse over"? Not sure if that is the right term - - when you move your mouse over a feature and information about that feature pops up without actually having to click the feature? Am I correct in thinking it is not possible to do this in AGOL?
I have also been playing with ArcGIS Viewer for Flex but I am so confused about adding my own operational layers (I guess I can convert the shapefiles from ArcMap to map services and then open them up that way by inserting the mapserver URL in the config.xml). Problem is I can't  access this REST endpoint to reference my service URL. It's just not there on my machine. I read last night that I need to have ArcGIS Server to do this?  Is that correct? If I don't need Server, does anyone want to tell me how to do this step by step. I am not finding any clear web sites to instruct me on how to do this.
Thanks!
AnthonyGiles
Honored Contributor
Joseph,
Yes you are correct that you need ArcGIS Server to serve your own data and access the REST endpoint.
You can create a map on AGOL for free (limitation of 1000 features in a shapefile) and bring that into your flex application, see "Defining data from a published web map" here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Main_configuration_file/01m3000...
I also believe that you can buy a subscription to AGOL which allows you to share your own data to a server in the cloud which you can then access via a REST endpoint in the flex viewer. You would have to contact your ESRI rep for pricing as it looks quite complicated.
Regards
Anthony
