Help Setting Up a Date Search
4086
14
05-02-2012 05:08 AM
heatherGrybas
Hi Everyone,
I'm kind of a flex viewer novice so I was hoping you would be able to help me out. I'm using the simple out-of-the-box Flexviewer application for a project where I work and I need to set up a date search. I have three data sets that are edited by outside users and each one has a date field that must be filled in when an edit is made. I would like it if someone could type a date into the search widget and receive a list, popup, etc. of the edits made on that date. My only problem is that I'm not familiar with how to set up a query expression in the XML file for the search widget. I would really appreciate the help if anyone knows how to do this.
As a side note: My data is stored in an ArcSDE database which stores date AND time together. I only want the user to have to type in a date and not the time (the time part is where I keep running into trouble but there is no way to eliminate it right now).
Thanks for the help!
-Heather
RobertScheitlin__GISP
Heather,
   I need to see your SearchWidget.xml file then.
heatherGrybas
Heather,
I attached a txt file
Heather,
   You have to have a titlefield specified.
Heather,
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
heatherGrybas
Wow. I can't believe I over looked that.
Thank you for the help!
-Heather
