Flex Viewer in internet explorer 9
1137
06-22-2011 01:18 PM
JoshWhite
Honored Contributor
I am having issues getting my flex viewer to show changes in Internet Explorer 9, the changes occur easily in Firefox.  I have cleared the Temporary Internet folder, cleared the REST cache, rebooted my machine and still I cannot get the updates to reflect in IE.  Anyone know of something that I might do in order to see the updates in IE like I do in Firefox?
Josh White, AICP
Principal Planner
City of Arkansas City
KariStringfellow
I'm experiencing the same problems.  In fact, when I set up the edit widget to allow only attribute changes, it doesn't honor the settings.  It still allows the user to add, delete, and change geometry.  The site works as expected in Internet Explorer versions 7 and 8.  Is the viewer not fully compatible with Internet Explorer 9 at this time?
Kari
JoshWhite
Honored Contributor
I found in another thread I believe that there are certain cleaners that work to remove all of the temp files and clear the cache.  The utility that I use can be downloaded from: http://www.piriform.com/ccleaner/
Josh White, AICP
Principal Planner
ChristopherButts
IE9 defaults to caching windows for a �??faster browsing experience�?�. If changes are made to any of our webpages you most likely will not see the change. You might want to change  this setting by going to:
Tools > Internet Options > Browsing History > Settings > Check for newer versions of stored pages: Every time I visit the webpage
