Heat Map Widget 3.0 Issue
1028
08-06-2012 11:16 AM
deleted-user-yA_w_FC9FKe5
Sorry for another Heat Map Thread but since this is 3.0 I thought it might deserve a new thread.
I've loaded the Heat Map Widget for my Flex Viewer App but when I throw it in my application and hit the button nothing pops up.  Not even the default logic or some logic I copied and tried thinking maybe I did not have access to the layer provided by the author.  Problem is that when I click the buton the icon sort of jumps but does not open a form like I was expecting.  Any thoughts.  I've loaded a few widgets and they seem to be working.  Would love to use this one.
<?xml version="1.0" ?>
<configuration>
<layers>
        <layer>
            <name>Earthquakes HeatMap</name>
            <url>http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/0</url>
            <outFields>YYYYMMDD,Magnitude,Num_Injured,Num_Deaths,Name</outFields>
   <useamf>true</useamf>
   <defaultquery>1=1</defaultquery>
   <querytemplate>Name LIKE '%REPLACE_STR%'</querytemplate>
   <types>CHILE,TURKEY,CHINA,PHILIPPINES,JAPAN,IRAN,INDIA</types>
   <type_descs>Chile,Turkey,China,Philippines,Japan,Iran,India</type_descs>
        </layer>
</layers>
<ui>
  <widget_dimensions>
   <width>378</width>
   <height>206</height>
  </widget_dimensions>
  <icons>
   <main_icon>i_rainbow.png</main_icon><!-- Icon must exist under assets/images in viewer -->
   <main_label>Main Panel</main_label><!-- Title/label for icon across the top widget panel -->
   <settings_icon>i_options.png</settings_icon>
   <settings_label>Settings Panel</settings_label>
  </icons>
  <refresh_label>refreshing layer...</refresh_label>
  <query>
   <comp_label>Earthquakes by geography:</comp_label>
   <heatmapquery_prompt>default selection</heatmapquery_prompt>
   <featurecount_label> features contained</featurecount_label>
  </query>
  <transparency>
   <comp_label>Transparency:</comp_label>
   <defaulttransparency>0.7</defaulttransparency>
  </transparency>
  <symbol>
   <comp_label>Theme:</comp_label>
   <defaulttheme>RAINBOW</defaulttheme><!-- Must be one of RED_WHITE_BLUE, RAINBOW, or THERMAL -->
  </symbol>
</ui>
</configuration>
All is good.  I figured it out.
JimWelsh
What was your problem?  I think I am having the same issue.  Thank you.
