HeaderController Question (2.2)
1155
04-25-2011 03:28 AM
SteveTest
I just noticed that even if the headercontroller widget is completely removed from the config.xml, there is still a white background placed in the headercontroller's original position.
My expectation was that the map would fill the screen without the headercontroller.
Attempted solutions:  in the config.xml I tried top="0" & mapTop="0" with the map.  First one causes a runtime error, second one is ignored.
Also, as an experiment, I hardcoded top="0" for <esri:Map  in MapManagerSkin.mxml but still that white gap persists and the map will not go to application top=0 !!
Anyone know the source of this white space/container ??
Steve
RobertScheitlin__GISP
Steve,
    You need to make sure you did not introduce a syntax error in the config.xml. I removed the header widget and set map top="0" and it work with out error.
SteveTest
Robert
Very good! -  problem is me & syntax in config.xml.
Thanks again,
Steve.
