Have graphical tool from search widget preselected when map opens
1678
10
06-23-2011 11:33 AM
StuartBlumberg
Hi, I am simply trying to get one of the graphical tools in the search widget to be the selected tool when the application starts.  This way the user can begin clicking away rather than having to click the select tool first.  I have the search widget preloaded when the app starts.  Believe me when I say that many people just give up when more than one step is required to view the data.  I'm using the Flexviewer 2.3.1 and server 10 and Robert's Enhanced Search Widget.  If you could just point me in the right direction I can probably work it out from there.  Thanks!
RobertScheitlin__GISP
Stuart,
    The new version 2.3.2.1 has that ability. It was easier to just add it than explain how you could do it.
StuartBlumberg
Robert,
I couldn't find any of the changed code in the configuration file or the mxml.  I did see where you added it to the Help PDF you included with the widget.
Stuart
Stuart,
   Hmmm... Try again.
StuartBlumberg
Robert,
I tried using the new code however it doesn't have the mappoint preselected when the app starts.  Then, if I click the mappoint tool and try to select a feature on the map it draws a blue point, as in the edraw widget.  It draws as many points as you click and it won't select any of the features.  Thanks.
Stuart
Stuart,
   Yep, I just noticed an the issue with the selectedgraphicaltool not working in the 2.3.2.2 version... As far as the graphical selection, as the documentation states you NOW draw as many graphics on the map as you desire and then click the search button under the draw buttons. Version 2.3.2.3 coming out in a minute to fix the selectedgraphicaltool issue and the inability to deactivate the graphical selection tool.
StuartBlumberg
Is this optional or is this a permanent change?
Stuart,
  Fixed in the now released Version 2.3.2.3
StuartBlumberg
Is there a way to turn off the mulipart geometry feature?  I was trying to eliminate as many steps as possible to make it as easy as possible for the officers to select incidents.  I would like them to be able to select a single feature and get results right off the bat.  This way they will see that all it takes to get results once the map opens is a single click on a feature.  This makes or breaks this application with certain people.  Thanks.
Stuart,
   The latest Version 2.3.2.4 now has that ability.
