Grouping layers from different services in TOC
1470
03-09-2012 04:53 AM
MattGiles
I am wondering if there is a way to group layers in the TOC that come from different services? I need to be able to do this for several reasons:
a. I have a number of imagery layers (that overlap each other) that require caching and need to be grouped together in the TOC. I cant group them in the mxd bc then i cant cache them since they overlap.
b. I want to be able to pull a single layer from a dynamic rest feed (not from our server) and group it with layers from our server in the TOC. In ArcMAP you can only pull the entire rest feed, and not specific layers from it.
If I could group layers in the TOC on the flex side, i could publish my imagery in different services and cache them. I could also load specific rest feeds from other servers as FeatureLayers, and group them with my services on the flex side.
Is this possible? Has anybody come across this issue before?
Ive been looking through the TOC package from viewer components but am fairly new to flex and am unsure of the best way to implement this in the TOC..
Thanks.
RobertScheitlin__GISP
M Giles,
   That is correct for both questions.
M Giles,
   If you search this forum for "Grouping layers" you will get 8 results and if you search the Flex API forum you will find 3 results.
MattGiles
Based on the threads you referred me to I gather the answer is no - the only way to group layers in the TOC is through the ArcMap document. Does this mean that layers that require caching cannot be grouped in the TOC since the cache would be generated for all the layers in the service (making it impossible to toggle specific layers on / off)??
M Giles,
MattGiles
OK thanks as always Robert.
