Google Street View
3395
6
04-16-2013 05:43 AM
rashaalharbi
I looking for Google Street View widget to add it in my application builder. I have Flex Viewer 3.2. Dose anyone knows how to add it, it is for my final project. Please I need help
I want to add widgets make the map better. ANY help
Thank you
Rasha
SeanSpansel
Thank you
Rasha
I had it working in v3.0, but with the upgrade to 3.2, it broke it all.  I've tried the past two days adding versions and messing with the config file with no avail.
Hoping to get a fix for this soon, was definitely an attention grabber on my map.
rashaalharbi
Ohhh, Do you know how I can use the version 3.0 and convert the v3.2 to 3.0. this might help me to use this widget.
SeanSpansel
You would probably have to uninstall and find the 3.0 version online somewhere.  Only problem I see would be downconverting your map application from 3.2 to 3.0.  I know you had to convert them from 3.0 to 3.2, not sure if it's reversible.
rashaalharbi
I don't think it would good idea but thank you for your explanation.
I hope if someone can help with add Google Street View widget in the latest version.
CarolKennedy
I also am looking for the update that works in ver 3.2.  Has anyone had any success with adding Google Street View in Flex 3.2?
RobertScheitlin__GISP
All,
   Here is a new Google Street View Widget:
http://forums.arcgis.com/threads/86574-Google%C2%AE-Street-View-Widget
