Google Street View Widget
5795
15
03-14-2013 05:51 AM
TinaCanady
The widget was working fine but for some reason I am getting this error now:
[FaultEvent fault=[RPC Fault faultString="Unable to complete Project operation." faultCode="400" faultDetail="Service 'Geometry' of type 'GeometryServer' does not exist or is inaccessible."] messageId=null type="fault" bubbles=false cancelable=true eventPhase=2]  Can someone tell me what this means?  Thanks.
TinaCanady
I did not know that you could use your own geometry service.  Okay so in what file do I make the change at?
RhettZufelt
MVP Notable Contributor
You will need to be running the source code, as that is set in the StreetviewWidget.mxml.
R_
TinaCanady
Thank you for all your help.  I still have alot to learn.
DevonHedemark1
Alright guys I have to ask... If you have an ArcGIS server why are you not using your own servers geometry service?
If you are using a compiled street view widget (Flex Viewer 2.5), is there any way to update the geometry service to your own ArcGIS Server service?  Does anyone have a compiled street view widget that allows a user to change the geometry service?
DevonHedemark1
It looks like the ESRI geometry service is back...problem solved.  I have to say I love all of these wonderful compiled widgets!   Great work by Robert and all of the other people building the flex widgets.
RobertScheitlin__GISP
All,
   Here is a new Google Street View Widget:
http://forums.arcgis.com/threads/86574-Google%C2%AE-Street-View-Widget
