Google Street View Widget
1127
10-31-2011 06:11 AM
HERSHSINGH
Hello,
I am trying to incorporate the Google Street View widget into an existing ArcGIS Viewer for Flex application.  I have successfully utilized the widget when creating the application from scratch using the compiled files which include the ArcGIS Viewer for Flex available for download here:  http://www.arcgis.com/home/item.html?id=f069d8a3aa304e29a432b48e5f64ca74
However, when I try to incorporate the widget into an existing application I often get error messages.  I have noticed that some of the index files included in the download are different from the default ArcGIS Viewer for Flex.
What files do I need to 'copy and replace' (in addition to adding the widget folder which includes the .swf and .xml) so that I can use the widget in my existing application?
I appreciate the help.
Thanks!
JanieGoddard
   I had to use the StreetView 2.4 Compiled version of the program. Then I copied in my custom config.xml file. I, of course, had to copy in my custom bookmarks, popups, and widgets. But it is working!
   I also found a "StreetView And More" that you can add to your Custom Flex Viewer (much easier).
My users prefer this one: http://www.arcgis.com/home/item.html?id=dc56d2ab11534d24a5559ea9dc8f5119
Hope this helps!
Janie
