Did you copy my index.template.html?
requires lines:
<script src="http://maps.google.com/maps?file=api&v=2.x&key=ABQIAAAAkSuRQhsVGwtKfC10t-cYMhTBpCie6Uzwqy2E6AELFrU6ooWJHRTCzw4I8uhjHu7YLeP32UUD8WWq3Q" type="text/javascript"></script>
<script type="text/javascript" src="widgets /StreetView/streetview.js"></script>
Check the casing of these lines
Venkat,
The ESRI map object has a logoVisible property which you can set to false.
Has anyone that has downloaded or used my code for the Street View Widget had any issues of late? Starting this week, all my apps that use the street view code have stopped working or has intermittent problems. Wondering if it's the api or something else that's going on here.
